Cat-back for Solara ? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 08-07-2002, 05:46 PM   #1 (permalink)
View dctodd's Photo Gallery
Hey is there a Cat-back made by any after market company for a 2000 Solara ?? If so how much does it run ?
Also curious to what you guys think my next mod should be, I just ordered new rims and tires this week. Was thinking rear sway bar, OR cross drilled break roters, HP brake pads, and steel breaded brake lines. Which do you think would have the most noticable effect ?? I know the sway bar would be the cheapest...
dctodd is offline   Reply With Quote
Old 08-07-2002, 06:57 PM   #2 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
View Jzs147-RR's Photo Gallery
Well you have a choice of 3 known cat back systems.
Greddy Evo
A'PEXi World Sport
Tanabe G-Power Medallion
All 3 of them range from 400-600$ depending on where you get them.
Also you should get an upgraded suspension before any other mod since it will give you that added safety all the way to the end of your moding stages.
5sfe powered turd ...
Jzs147-RR is offline   Reply With Quote
Old 08-07-2002, 09:07 PM   #3 (permalink)
Man on a mission...
View SKYravefever's Photo Gallery
rear sway
A set of sway bars will be a cheap and noticable mod that you may want to consider. The general consensus is that it's a day and night difference.
Time is never wasted when you're wasted all the time.
SKYravefever is offline   Reply With Quote
Old 08-08-2002, 09:23 AM   #4 (permalink)
Thanks for the replys !! I actually have already done my suspension, Eibach pro kit, and KYB struts. Will I lose any power on my low or high end with adding a Cat-back ??
Have people heard of White-Line sway bar ?? IS it any good ?? better then the TRD one that toyotaparts4U.com has online for $145 ??
Thanks !
Old 08-08-2002, 09:42 AM   #5 (permalink)
Sorry guys, ANOTHER Cat-back question. If I went ahead and got a cat back system but have no other engine mods, would I notice any difference in how my engine preforms either good or bad ???
I know by adding a cat-back system I am not going to get major HP improvement, but wondering if it's even worth it at all ??
What are you're guys experiences ??
Old 08-08-2002, 04:11 PM   #6 (permalink)
Luc
View Luc's Photo Gallery
Dave, you will probably get the best performance with a Y-pipe along with the cat-back system, which will allow a better flow. For the RSB, the TRD is adjustable to either street or track settings. Street has an effective 19mm, track has 21mm, and Whiteline is about 20mm, in between the TRD. The Whiteline can be bought for almost half the price of the TRD.
Luc
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
