Well if you get replacement Toyota pads, you can just reuse the shims that are on the pads now. Most aftermarket pads will come with shims to use. The caliper bolts can be reused. I would recommend getting OEM rotors and pads, seem to be the quietest to me. Only tools you are going need are a 14mm wrench for the caliper bolts, a 17mm wrench for the caliper bracket bolts and a pad spreader. The rotors are sometimes pretty rusty and you may have some issues getting them off, so I would recommend if you have this problem, run a couple bolts in the holes on the face of the rotor and it will push it right off. Hope this helps
