Changing Automatic Tranny Fluid in '03 Solara - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 06-26-2005, 09:50 PM   #1 (permalink)
View Nippon-3RE's Photo Gallery
This question is for all the people who own the 1st gen Solara equipped with the new 2.4 liter 4 cyl engine. I did a search for this topic but did not find anything.
Has anyone here changed the ATF in their Solara? If so how many quarts of ATF do you put in it before starting the engine and running the gear selector through each range to add more fluid?
Thanks for the replies!
Nippon-3RE is offline   Reply With Quote
Old 07-01-2005, 05:00 PM   #2 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
i think it might be 8
not sure though...
skewe is offline   Reply With Quote
Old 02-17-2006, 12:43 AM   #3 (permalink)
View marc780's Photo Gallery
Ask the dealer to look up this info for you, cause thats the only place where you can get toyota T IV fluid for $4 qt. Use no other fluid Toyota says it will mess up your shifting if you try to use any other kind.
Old 02-19-2006, 06:17 PM   #4 (permalink)
MDT Toyota Tech
View BadChicken's Photo Gallery
if your just draining the fluid out and filling it back up it will be between 3-4 qts depending how long you let it drain, I would put 3 in and then run the car and check and adjust the level as needed
BadChicken is offline   Reply With Quote
