cigarette Lighter(accessory Outlet) - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 07-31-2005, 08:17 PM   #1 (permalink)
View tekvaio's Photo Gallery
My 2000 Solara's second accessory outlet is not working and as far as I remember never worked. This is the lower one below the ashtray. Would anybody know where the fuse may reside(Under the hood near the battery? or in the panel inside the car?) The top one works fine. Also, at one time the ashtray light worked, now it doesn't.
Any help is appreciated.
Thanks,
TV
tekvaio is offline   Reply With Quote
Old 08-01-2005, 02:01 AM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $398685
View RningOnFumes's Photo Gallery
both should go to one fuse..most likely the Accessaries fuse. So if the other one is still good, you have a wiring problem---follow it to the source
i may be wrong
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 08-01-2005, 08:15 PM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
check the fuse behind the outlet itself..there should be another one there too...maybe, i think...
terrastrife is offline   Reply With Quote
Old 08-03-2005, 10:04 PM   #4 (permalink)
Stock Sleeper
1st Gen Sol's Avatar
Gameroom cash: $107505
iTrader Score: 7 reviews
View 1st Gen Sol's Photo Gallery
or you might have a loose connection behind the outlet itself.
1st Gen Sol is offline   Reply With Quote
