Oil in spark plug hole?? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 08-16-2005, 09:25 AM   #1 (permalink)
100% Pure "White-Trash"
View WhiteTrash2775's Photo Gallery
Question Oil in spark plug hole??
Hey everyone quick question, when I did a tune up on my car last night I noticed oil on the spark plug boot from the #4 cylinder, when I looked down in there I saw a puddle of oil. Is there some kind of gasket or gromet that could be bad that is causing oil to get in there? And if there is do I need to take off the valve cover to get to it?? Thanks in advance everyone.
or
Brian wich ever you prefer.
01 Solara SE
2.2L Four with 5spd trans
with
Cherry Bomb Turbo muffler and removed resinator and a cone filter on stock intake.
Last edited by WhiteTrash2775; 08-16-2005 at 09:44 AM. Reason: want to add a notification
WhiteTrash2775 is offline   Reply With Quote
Old 08-16-2005, 10:19 AM   #2 (permalink)
View Calvin327's Photo Gallery
The seals are broken. To fix it, replace all 4 seals, valve cover gasket.
Make sure to check the tubes, to see if they are messed up.
Good Luck,
Calvin
Calvin327 is offline   Reply With Quote
Old 08-24-2005, 08:13 AM   #3 (permalink)
Good Luck,
Calvin
Yup it was the seals, none of them where broke but after replacing them and the valve cover gasket there is no more oil in that tube or any of the other ones. Thanks for the help bro.
or
01 Solara SE
with
Old 09-23-2005, 03:49 AM   #4 (permalink)
View SLPJCooL's Photo Gallery
What would Happen to the Car if Oil is leaked into the Spark Plug Hole???
SLPJCooL is offline   Reply With Quote
Old 04-26-2010, 10:09 AM   #5 (permalink)
View OpenBoltMac's Photo Gallery
oil in plug hole
The oil will eventually short out the plugwire, causing no ignition fire to the affected cylinders as I found out yesterday with my '94 Camry on 2 of the cylinders.
OpenBoltMac is offline   Reply With Quote
Old 04-26-2010, 06:31 PM   #6 (permalink)
AnglerfisH's Avatar
View AnglerfisH's Photo Gallery
Agreed, oil in the spark plug tubes and plug boots, bad! I had that problem with my old car, '99 Altima GLE, only it was cylinders 1,3,4
2000 Solara Coupe in Diamond White Pearl
Philips X-treme Power halogens
K&N Drop In Filter
AnglerfisH is offline   Reply With Quote
