Please answer if you know about solaras - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 08-30-2005, 07:54 PM   #1 (permalink)
View jenkins24's Photo Gallery
Question Please answer if you know about solaras
I have just bought a 2001 Toyota Solara with 37,000 miles. It still has its factory warrenty and I would like someone who knows about Solara or Toyoyas in general to tell me what I should have cheacked out, maintained, or fixed. Thanks a lot hope to start learning more about Toyotas.
Thanks,
Chris
jenkins24 is offline   Reply With Quote
Old 08-30-2005, 08:21 PM   #2 (permalink)
View foompla's Photo Gallery
factory warranty is 3 years 36 k? unless you have an extended
foompla is offline   Reply With Quote
Old 08-30-2005, 08:29 PM   #3 (permalink)
Noob :-)
View ST185's Photo Gallery
Congrat on your new car.
Solara is a good car. Take good care of it and it will out last many many cars.
You should first check when was the car get tuned up.
Just follow your owner manual, starting from basic maintenance.
Oil change, air filter, new coolant, new transmission fluid, new brake fluid, plugs and wires, etc...
93 ST185
ST185 is offline   Reply With Quote
Old 08-31-2005, 03:33 AM   #4 (permalink)
View rufus129's Photo Gallery
wow you got a really good condition car. considering it a 01 w/ only 37k.
congrats on your new car & welcome to the forum.
you should probably just change out all the fluid and check the rotors and brake pads.
rufus129 is offline   Reply With Quote
Old 08-31-2005, 04:47 PM   #5 (permalink)
what all is covered on the power/tran warranty?
Old 08-31-2005, 04:57 PM   #6 (permalink)
cam2Xrunner's Avatar
Engine, and any moving parts on it, such as the waterpump. Transmission, driveshaft's.
There probably isn't anything wrong with your car at all, those things are pretty bulletproof.
Check the trans dipstick, if the fluid is brown and not pinkish red, go get your trans flushed.
Old 09-01-2005, 12:17 AM   #7 (permalink)
View RGB Guy's Photo Gallery
It would help if you got info on the previous owner. If it was cared for, you shouldn't have to worry about anything for another 20 or 30k miles. But just like any car, if it was drivin hard the first 3k miles, it's gonna have a higher chance of problems...
RGB Guy is offline   Reply With Quote
Old 09-01-2005, 12:34 AM   #8 (permalink)
Moving Forward
View Cyorke's Photo Gallery
As long as you ahve the remaining factory powertrain warranty about hte only thing you may have problems with is water pump, crank and cam seals tensioner and idler pulleys. SOmetimes they will go out in the first 60k miles but not very often. If you get the t-belt replaced before the 60k mile mark or 5 years whichever comes first you may be able to get those parts replaced if they need it at the time you do the belt. BEsides that the only other thing is maybe the transmission pan leaking a little bit around the gasket. We used to replace those under the powertrain warranty fairly regularly.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 09-01-2005, 11:24 PM   #9 (permalink)
Toyo Slow-Arwa
DatSRBoi's Avatar
View DatSRBoi's Photo Gallery
Solaraguy.org..... Check out this forum.. We got lots of car solara mantaining on that site if I remember.. Welcome.
Also you should check the spark plugs and oil and see if it needs changing.. With that millage the car is still young and nothing on it shuold be wrong yet if taken cared of.. Toyota are lasting cars..
Goodbye supercharged Solara, Hello turbo supra
DatSRBoi is offline   Reply With Quote
