If the Solara is anything like the Camry, which it should be, then you will need to remove the back seat, which gives you access to the bolts holding in the two outer parts of the seatback that does not fold down. Remove those outer parts. Now, there may be some small screws holding in the speaker shelf. Remove those screws then tug at the shelf. This would expose the speakers. The rest should be straightforward.
I'm SUPER, thanks for asking;
All things considered I couldn't be better I must say.
I'm feeling SUPER, no, nothing bugs me;
Everything is SUPER when you're...
SUPERCHARGED!
