Transmission and Transaxle Fluid for 01 SLE convertible? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 09-22-2005, 08:37 AM   #1 (permalink)
View rvogel's Photo Gallery
I'm trying to change the transaxle fluid but can only find drain hole. I cannot find fill hole. Is it true that transaxle fluid in 2001 solara v6 is same as transmission fluid and that both are filled from same place? Thanks.
rvogel is offline   Reply With Quote
Old 09-27-2005, 03:48 PM   #2 (permalink)
View clr_118's Photo Gallery
There is a separate fill hole for the transaxle. It is further up on the transaxle. Both the transmission and the transaxle use the same type fluid, but you need a pump or syringe to get it in the hole.
clr_118 is offline   Reply With Quote
Old 09-28-2005, 06:13 PM   #3 (permalink)
StockSolara's Avatar
View StockSolara's Photo Gallery
In my 2001 SLE V6 there is a transmission dip stick to the left of the Cruise Control Unit by the battery. . . You can fill it through that hole
StockSolara is offline   Reply With Quote
