I had a similar problem with a delay or echo in the subs when they pound.
It turned out to be a few things:
1. The shitty amp I was using didn't handle the voltage my Sony ES deck was putting out over the RCA cables, even at it's lowest gain setting.
2. I was using rca cables that had been patched more times then I care to admit.
I ran new rca cables and got an adapter that converted line level to high level... so the rca cable went into an adapter, and speaker wires came out, which attached to the high (or speaker) level inputs on the amp. (if you look at the pictures of the amp on ebay, it's got high level inputs too. not all amps have em.)
Worked flawlessly after all that.
