Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - What are your suggestions?
View Single Post
Old 09-07-2001, 01:35 AM   #4 (permalink)
speedemn
View speedemn's Photo Gallery
With the money you're gonna end up spending on that you could get like two MKIV Supra TTs! haha...
But I REALLY do hope you can get this done on your gen 3 I4. I'd definetly like to see your progress. I thought up of similar mods to do to my gen 3 I4 and I came up with something like what you just said, but the cost was too much to consider actually doing anytime soon. But I'd like to see how much it costs you and stuff.
Where are you from?
On 2001-09-06 20:53, karma wrote:
i have a gen3 1994 camry coupe rally red, i'm plannin on going custom route with the turbo kit, use a 3sgte exhaust manifold and maybe either a t360 or ct26 turbo, hks ssbov, boost dependant fuel pressure reg and custom down pipe ran at 5 psi for now while i build up another 5sfe with lower compression pistons and hi strength connecting rods flowed head and TB, lightweight flywheel, metal gasket and hi profile cams, plus redone fuel system for boost needs and intercooled so that then i can run 11 psi to 14psi, hopin for 300 hp with NOS but it's all for show would only run it a couple times and occasional street encounters, possible low 14's maybe a 13 someday. thats the dream gonna make it happen one day but dont knoe if i should do both slowly at the same time or work only on the supra and knock that out in a year while i pay off the camry.Oh and true dual exhaust and fuel cell
Plans for the supra are High compression pistons, maybe 11.0:1 or 12.0:1 and over bored maybe to 3.2L or 3.5L if i can find them, hi profile cams with better valve springs, metal headgasket, stand alone Fuel system, headers/exhuast 2.75 all the way back, redone cooling system, custom cold air, stand alone radiator fan, redone ignition system, complete adjustable suspension system, lightened body. and kit for looks
2003 BMW 540i 6-spd
2008 Toyota Rav4 Limited V6
2005 Mazda 3 Sport GT 5-spd (just sold)
1995 Nissan Maxima SE 5-spd... Best ET: 13.8... Best trap: 99mph (Gone)
1993 Toyota Camry LE (Gone)
speedemn is offline   Reply With Quote
