umm strip the carpet if u havent already. also take out all tht crap in the trunk like Chris Corolla said. i mean theres tons of things u can strip but the question is how much is enough? like 100 pounds will be about .1 seconds in the quarter i heard somewhere
strip the seats and spare and go to the drag on like E hardly any gas in ur tank u should be fine. i go to the drags alot in my camry but i run it as is i take nothing out......
take the alternator out, if you want to go hardcore.
you'll need to charge your battery between runs, it'll cut down some weight and kill off a lot of powertrain loss.
Then you won't have a radio, so no need for any antenna at all! You wouldn't even bondo the hole, a little celophane tape works
"The lamest twice banned, non-female member of-all time." -Ekam, Thanks, I <3 you too! AIM/Yahoo Toysrme257th
for anything, anytime; including camry turbos Now with Turbo!
I've never heard of anyone doing that. If anything, you just take off the belt before racing. Removing it would be rediculous. It only weighs like 5 pounds. And old requires about 5 hp to power it.
If your wanting to loose weight, peal back the carpet in your car. Under it is a tar based sound insulation. You can remove that by heating it with a hairdryer and scraping it off with a paint scraper. There is about 40lbs right there.
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
that's a valid idea, but a lot of the guys who go balls to the wall with drag do run without alts. most of the time they bring an extra battery so one can be charging while the other is being used for their run.
it's a way of cutting down drivetrain loss and it will reduce weight marginally.
if you're removing ac/ps/cc, you might as well go with unbelting the alt for runs.
similarly, you can use an electric water pump to reduce drivetrain loss even further.
