??? on Injectors... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition > Drag Racing
Drag Racing Discussion area for everyone who is interested in drag racing info.
Old 04-17-2005, 09:33 PM   #1 (permalink)
2rz Turbo Tacoma Project
View Teamsdsu's Photo Gallery
Question ??? on Injectors...
I'm new to this site so please bear with me.. I have a Toyota Tacoma 2rz 4cyl motor that I am turbo charging. I have the block bored 20 over and have (8.5 - 1) ARIAS pistons with the 4030 cromoly steel Pauter rods. I am Currently on the fuel issue... My stock injectors flow 282 cc's per minute and I plan to run 12-18 lbs. of boost. Will this be enough fuel flow if I get a walbro 190/lph High Pressure pump?? Any help on the fuel situation would be greatly appriciated. Also I have a APEXI S-AFC unit I am installing as well (I don't even know what the thing does, other than change the injector pulse) But I bet it will look prety cool!
Teamsdsu is offline   Reply With Quote
Old 04-30-2005, 09:26 PM   #2 (permalink)
A little help, please...
Nobody knows??? Come on guys I know someone has some info....
Shawn
Old 05-01-2005, 10:20 AM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
That doesn't tell anything useful. First figure out what turbocharger you're using, then look that up on the compressor map in lbs of air / min. THEN you can see how much power you're going to roughly be making, and size injectors from there.
And no, 280cc injectors are definately NOT going to be enough fuel.
Injector size in cc / 5 = approximate horsepower
approximate horsepower * number of injectors.
280cc/5 = 56hp
56hp * 4 = 224hp
224hp * 90% duration (so the injector doesn't burn up) = 201hp
So just running a "standard" fuel pressure, those are good for a safe 200hp. You'll definately want to add a larger injector, or swap them out.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 05-01-2005, 10:23 AM   #4 (permalink)
Toysrme's Avatar
Cool
The SAFC doesn't change the injector pulse. It modifies (whatever your style of) air meter is. It fools the engine into thinking there is more, or less air entering the engine than there really is.
Indirectly having the ECU change injector duration.
Now with Turbo!
Old 05-06-2005, 11:22 AM   #5 (permalink)
Team Nex-Gen
View GSoccer24's Photo Gallery
you'll need bigger injectors..probably could use 440cc
2006 Chevy Cobalt SS Supercharged Coupe
"The New Breed of Speed."
GSoccer24 is offline   Reply With Quote
