1991 PREVIA, looks pretty good. Trying to get it on the road. Last owner drove it up to about two years ago and then parked it. We jumpered the battery, it started right up, I bought it, trailered it home, drove it around the yard a couple of days, got the license plates, then pttt! It will not start.
Battery charger on it and it spins real fast, but never fires. Maybe once or twice I heard what I thought was almost a fire of one cylinder or so, very short sput.
After I finally found the engine...
I took off the plug wires, looked good. Took off the distributor cap and other than grease and oil on the outside, which I cleaned off good, the inside looked OK, other than the rotor must not run on a true center of the cap because two of the inner points of the dist cap were worn smooth to the inner phenolic surface and the top two had no visible sign of contact at all, so I suspect it had been running this way for a long time.
It looks like the ignition coil had been mounted upside down at one time because the distr spark wire was touching the tight ground wire that grounds the outside body of the ignition coil. I remounted it properly but still it does not fire. I pulled one plug wire and with a couple of screw drivers tried to see if there was any spark, which I never saw, but that test was one of the times that I thought that it might have almost fired, so I reasembled everything and said Oh Boy it's going to work! Wrong.
So to me it seems like it is an ignition problem, but it could be something else entirely. For instance I have cranked and cranked and cranked it many times and I still have never smelled any gas smell. Seems like it would flood after so many times, but I have no idea what to look for.
I live in the boonies and there ain't no Toyota mechanic within many miles, I would have a couple of hundred dollar tow job to even have it looked at. One of the forum messages that I found suggested a broken timing chain, but I had my neighbor crank it over while I went under to watch the distr rotor and it seems to turn nice and even with the cranking. Is there such a thing as perhaps jumping a timing chain cog? And if so, how would I be able to check that?
All offers of assistance, or donations of huge piles of cash, would be greatly appreciated!
Presuming I do get it going, then I want to order some ignition parts just to be safe, so I would appreciate any references to reputable and fair online parts houses for this old beastie girl.
Thanks in advance.
PREV91RH
