Wet floor mats - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Go Here First > Introduce Yourself Here
Introduce Yourself Here Let us know all about yourself and your car. Break the ice in here.
Old 07-15-2006, 10:17 PM   #1 (permalink)
View nicksty's Photo Gallery
Question Wet floor mats
Hey,
My driver side front floor panel is soaked in my 2002 Camry. Since it's 90+ in Boston, I've been using my A/C constantly. I sure I have a block somewhere. Any ideas?
Thanks
nicksty is offline   Reply With Quote
Old 07-16-2006, 12:31 PM   #2 (permalink)
Dave's
Gameroom cash: $124850
View Dave's's Photo Gallery
Should be able to locate the drain hose which runs from the A/C, down the firewall and thru the floorboard. Assuming it's connected you should be able to locate it under the car and run a flexible rod up it to clean out any clog.
Dave's is offline   Reply With Quote
Old 07-18-2006, 07:45 AM   #3 (permalink)
Question
Do I need to pull the carpet to get to the drain hose? I looked under the car and did not see anything that looked like a hose. I appreciate your response. I may have to bring it in if I'm not successful.
Thanks
Old 07-18-2006, 08:02 PM   #4 (permalink)
View toyomoho's Photo Gallery
The hose located inward on the frame and difficult to see unless you are under the car. You could try to pull back the carpet from the firewall near the A/C.
Old 07-20-2006, 08:04 PM   #5 (permalink)
View red01le's Photo Gallery
Air condtioning drain hose
I just found the drain tube on my 01 camry. I lifted up the front passenger carpet and it was on the left. I stuck a cat hanger about 6 inches in and about a gallon of water came out. ( I had to quickly put the hose back into the floor where it drained to the outside.) My first post, Hope this isn't too late
red01le is offline   Reply With Quote
Old 07-23-2006, 11:53 AM   #6 (permalink)
USA
Thanks,
I brought it in to the dealer and they supposedly fixed for $85. But my carpet is not getting any drier. I'll wait a few more days and see, but thanks everyone. I'll know for next time.
Wet Carpet from Water Leak & Toyota Service TacoSport05 2nd Generation (2005+) 12 01-10-2006 12:23 AM
'90 corolla floor gets wet during rain bgtg Archived Corolla threads 0 11-29-2005 08:27 PM
spark plug wet with engine oil tightcamry129 Camry & Solara Lounge 11 08-10-2005 08:58 AM
