Hi from Pa buying 93 4wd pu that needs engine work!
Hi, I'm going to be a 93 toyota 4wd pick-up owner Monday.
Here is the story.
A buddy of mine has a 93 4wd pick up with 130,000 in pretty good shape. One day after work he started it and it was knocking and squealing out of the blue. He shut it off and had it towed to his house, it has been sitting there for two years, he never looked into what was wrong. He said it aways ran good, did not use any oil, just minor usual problems (starter,fuel pump both replaced).
I plan on buying it from him Monday for $500. What do you think the knocking and squealling noise is? I'm hoping it's just the bottom end bearings. If not I plan on getting a short or long block for in it worse case.
I will have a decent truck for $2000.
I'm no car mechanic, but I have changed engines in the past and I'm confident I can do this.
I have been doing research on remanufactured engines, anything special I should be looking for?
Any ideas or info on getting this truck on the road would be appreciated.
