1996 Paseo PO171 code - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Go Here First > Introduce Yourself Here
Introduce Yourself Here Let us know all about yourself and your car. Break the ice in here.
Old 05-14-2007, 09:57 AM   #1 (permalink)
View finebird's Photo Gallery
Canada 1996 Paseo PO171 code
Hi,i have a po171 code that dont whant to go away.my paseo is a 1996 automatic with 5efe engine with MAP sensor not the MAF one.I have done a obd2 check with proscan program and here are the results:
Freeze frame data:
Load:64%,Stft: 2.34, Ltft: 33.59, Imp: 9.28inhg, speed 45kph, rpm: 2023, Ect: 172 F,
All test came back ok except for catalyst that says incomplete.I have check the o2 sensors and the upstream one seems to works ok = 0.2 to 0.8v with ok fluctuation.
Downstream one is almost flatliner with 0.1 to 0.2v variation.
I have check for vacuum leaks and did not notice any.Car has new spark plugs and recent injection system clean up by toyota dealer.
Can the downstream o2 sensor give a po171 code? the non continuous monitoring tests says o2 sensor are ok.Any ideas what is going on?
Thanks in advance for your time
finebird is offline   Reply With Quote
Old 05-14-2007, 09:31 PM   #2 (permalink)
Boss Honky
YESCA's Avatar
iTrader Score: 29 reviews
View YESCA's Photo Gallery
Check out our Paseo fourm, maybe someone there had the same problem and can walk you throught it. Let me be the 1st to welcome you to TN.. Glad to have you here! BTW good luck on your little problem, I'm sure it will be resolved quickly! WELCOME!!!
OG Team HAMSTER
O.G. Team HAMSTER violated my mom for food stamps
OHIO FORCE!!!
YESCA is offline   Reply With Quote
Old 05-15-2007, 09:19 AM   #3 (permalink)
Boss Honky
YESCA's Avatar
Welcome!
OG Team HAMSTER
OHIO FORCE!!!
Toyota Engine code vivian General Discussion 22 12-27-2008 01:16 AM
1992 Paseo JT2EL45F2N0097655 PatPend Vehicles 3 02-26-2007 02:03 PM
1996 Paseo Body Parts do-u-22 Tercel, Paseo, Starlet, and Sera Forum 7 05-22-2006 08:20 PM
92 Paseo - check engine code 25 - running too lean... Wondernaut Tercel, Paseo, Starlet, and Sera Forum 9 04-07-2005 09:51 PM
need engine code for paseo type s king3 Tercel, Paseo, Starlet, and Sera Forum 4 03-11-2004 08:06 AM
