2001 Sienna owner - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Go Here First > Introduce Yourself Here
Introduce Yourself Here Let us know all about yourself and your car. Break the ice in here.
Old 09-17-2007, 10:43 AM   #1 (permalink)
View cfacmc's Photo Gallery
2001 Sienna owner
Hi, my name is Carl. I have a 2001 Sienna that has given me great problems, and I have found fixes through my local shop. First - if you have K&N air filters, the mass air flow sensor gets loaded with oil, and causes engine problems. Knock sensors, ignition coil, Chk Engine Light, bad mileage, fuel pump failure or very low pressure, power, starting and acceleration trouble. Remove the K&N to start, and you may have to replace all the above items to fix the trouble. My van runs like new again. Of course it took ten days and $2200 to do that...
cfacmc is offline   Reply With Quote
Old 09-20-2007, 12:43 AM   #2 (permalink)
Boss Honky
YESCA's Avatar
iTrader Score: 29 reviews
View YESCA's Photo Gallery
The only reason that would happen is if you over oiled the K&N filter. I can't tell you how many times I have seen that problem happen here on on friends cars. i have a K&N and I have not had a problem with it in years. Glad to hear than everything is running great again, to bad for that repair bill. Welcome to TN!!!
OG Team HAMSTER
O.G. Team HAMSTER violated my mom for food stamps
OHIO FORCE!!!
YESCA is offline   Reply With Quote
Old 09-20-2007, 11:19 AM   #3 (permalink)
Thanks, but I am scared off K&N for good to the tune of $2500!! I was very careful to follow the specs when cleaning and recharging the filter, and thought it looked like I was UNDER-oiling them. This is not an isolated incident - the shop tech read about the problem in a tech tips magazine for technicians, so it has happened frequently enought to get into print. I have asked the shop owner to get me a copy of that article.
Old 09-20-2007, 04:44 PM   #4 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
I never got into the modified filter thing. You would be amazed at the strange problems it creates. Just had a mazda come in today that wouldnt run. A small peice of coating from the wire mesh on the filter came off and shorted out the mass airflow sensor. Best part was it didnt even throw a code. But anyway, as far as toyotas go siennas seem to be a little more problematic but you should be able to get plenty of help on here. Welcome to the site!
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
2007 Sienna Upgrades Thundercat Toyota News 7 09-27-2006 11:12 AM
2001 Sienna code problem domino_harvey 1st Generation (1998-2003) 1 06-02-2006 06:21 PM
2001 Sienna went to get an oil change. Oil Plug loose, leak all the oil ...what now? 2k1Sienna 1st Generation (1998-2003) 3 11-29-2005 09:16 AM
Whistling sound in Sienna 2001 swadeshi General Discussion 3 02-05-2005 11:27 AM
