problem with electrical / head lights - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Go Here First > Introduce Yourself Here
Introduce Yourself Here Let us know all about yourself and your car. Break the ice in here.
Old 11-27-2007, 06:45 PM   #1 (permalink)
View taracox's Photo Gallery
UK problem with electrical / head lights
1982 Pick up diesel
Head lights, turn on off of there own free will which of course is problematic for night driving!
I'm assuming it can't be the fuse. I'm also going to assume it is a problem with wiring once the two sides come together as both go on and off together. If I flick the switch on and off they come back on sometimes. Is it possible its the switch mechanism. The dash and rear lights stay on at all times.
If anyone has any ideas of how to go about fixing this, or exactly what the problem is I would be glad to here from you.
taracox is offline   Reply With Quote
Old 11-27-2007, 06:54 PM   #2 (permalink)
View toyomoho's Photo Gallery
Might check the wiring at the connectors, had similar problem due to corrosion at the connector. With lights on start probing and pulling on the wiring under the dash.
Or could be the light switch or headlight relay. Sometimes the headlights are on circuit breakers instead of fuses.
problem with tail lights t_cel_t 1st & 2nd Generation (1983–1986 & 1987-1991) 3 11-13-2007 02:59 PM
How to remove the valve cover. 2slo5sfe 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-09-2007 12:26 PM
92 Camry XLE electrical problem davedeitch 3rd & 4th Generation (1992–1996 & 1997–2001) 4 05-31-2007 10:27 PM
HELP!! electrical problem during boost gauge install... fallingsux MR2 Forum 2 08-17-2005 05:33 PM
94 corolla electrical problem al_sniperrolla Archived Corolla threads 0 10-16-2004 10:42 AM
