Tail Lights are Out - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Go Here First > Introduce Yourself Here
Introduce Yourself Here Let us know all about yourself and your car. Break the ice in here.
Old 11-29-2007, 05:37 PM   #1 (permalink)
View LovemyCamry's Photo Gallery
USA Tail Lights are Out
My back tail lights don't work. I know where the problem lies. It is where the trunk the slides & that allows the trunk to open and close. Well I noticed that a few wires were cut. At the dealership, and at the time only lights were out were the lights on the trunk itself. Dealership said that it would be still good to drive at night. They said that is a common problem with the Camry's wires getting cut by the trunk.
Now, they don't work at all. I am just wondering if I can re-connect the wires myself? I would use electrical tape. Or should I take it to someone that knows what they are doing. Dealership said it would cost about 200 - 300 dollars for the repair. Or is there a manuel that you can recommend? Its a 99 Camry LE
LovemyCamry is offline   Reply With Quote
Old 11-29-2007, 06:21 PM   #2 (permalink)
View toyomoho's Photo Gallery
If you know where the broken wires you can reattach them together based on wire color. Each wire should have its own color such as Black with a White stripe. Normally there is only one wire to be attached to the other so just reattach by same color.
One route is to go to a hardware or auto parts store and find crimp connecters that can be used to reattach the wires. Have the sales person explain this if you can’t figure it out. You can use a pair of pliers to crimp the connector to the wire instead of the special tool usually used. Take note of the wire diameter that needs splicing, the connector size varies with wire diameter to be spiced.
If you don't have time just reconnect and tape each wire then wrap tape around the wire bundle.
It is very typical for the wires to break at the trunk hinge location you describe and common for owners to splice the wires back together. Once all the wires are spliced wrap electrical tape around the wires to add some protection.
The link below provides excess to a Camry manuals and wiring diagrams:
http://www.camrymanuals.com/
Tail lights electrical issues snosheriff 7th Generation (1993-1997) 11 11-10-2009 01:53 AM
2000 Camry Trunk Tail Lights Not Functioning ds_1910 3rd & 4th Generation (1992–1996 & 1997–2001) 12 04-19-2008 07:03 PM
You Have To Check Out These Tail Lights chuloloco Camry & Solara Lounge 0 11-25-2007 11:04 PM
HOW TO: Blacked out tail lights ekopel 3rd & 4th Generation (1992–1996 & 1997–2001) 23 09-22-2007 12:33 PM
head lights and tail lights hks55 Supra Forum 9 03-23-2005 12:13 AM
