Question about Leveling Kits - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Go Here First > Introduce Yourself Here
Introduce Yourself Here Let us know all about yourself and your car. Break the ice in here.
Old 01-05-2008, 07:30 PM   #1 (permalink)
View Pastor Russ's Photo Gallery
I have a 2005 Tundra Double Cab 4x4. I would like level the front end and back end but I was concerned I might loose the smooth ride I currently have with this truck. My question is will a leveling kit make my truck ride ruff? If not, what is the best leveling kit to go with? Thanks
Pastor Russ is offline   Reply With Quote
Old 01-07-2008, 10:18 AM   #2 (permalink)
Top Gun Customz's Avatar
View Top Gun Customz's Photo Gallery
If you use a steel leveling kit, you will be able to keep the factory ride quality. However, when using a polyurethane leveling, kit a spacer is usually installed between the coil spring and the top of the strut. This puts preload on the spring which can stiffen up the ride. It has been reported that the polyurethane kits can cause over-extending of the strut which may cause premature failure.
After installing a leveling kit, you will need to have an alignment done.
Top Gun Customz is offline   Reply With Quote
Old 01-07-2008, 10:28 AM   #3 (permalink)
Thanks for your reply. Do you know how much it would cost to get a steel leveling kit installed on my tundra? And where? Thanks
leveling & ride quality questions nomad 2nd Generation (2005+) 10 11-06-2005 07:29 PM
Roll Bar kits Just $169.95! Bolt in kits start at just $269.95! From Safedrives.com Safe Drives Supporting Vendor Sales 10 10-13-2005 05:04 PM
Camry Kit Question Huffster Camry & Solara Lounge 6 08-30-2005 11:39 PM
GoupBuy For Camry Dash Trim Kits AutoAccessory Supporting Vendor Sales 23 05-07-2005 05:17 PM
