88 Camry side gear shaft removal? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Go Here First > Introduce Yourself Here
Introduce Yourself Here Let us know all about yourself and your car. Break the ice in here.
Old 01-09-2008, 03:09 AM   #1 (permalink)
View markedward1's Photo Gallery
Question 88 Camry side gear shaft removal?
I want to remove the side gear shaft on my 88 camry.
The shaft is on the driver's side.
I already have the CV axle off.
Some say to use a pry bar.
Some say to use a slide hammer.
If this side gear is forced off, will any harm be done.
My tranny type is S51, 5 speed manual transmission.
markedward1 is offline   Reply With Quote
Old 01-09-2008, 01:39 PM   #2 (permalink)
View toyomoho's Photo Gallery
Not sure what you mean by side gear.
Old 01-10-2008, 01:34 AM   #3 (permalink)
Talking 88 camry side gear shaft intermediate shaft
The side gear shaft according to Haynes and the Toyota manual is aka the
intermediate shaft, left or right side.
This shaft is the "intermediate" connection between the CV (Constant
Velocity) Axle and the transmission itself = CV axle to intermediate or side
gear shaft to the tranny (three parts total).
I am dealing with the left (driver) side which after consulting with the
internet and a respected general auto mechanic friend the conclusion is as
follows.
1. A slide hammer can be used
2. A pry bar can be used
3. Two large standard screwdrivers can be used (mechanic's choice)
4. A 2 foot crowbar can be used (my choice)
used to simply and easily pry the intermediate shaft out.
I suggest that you have an oil pan underneath the pry area because tranny
fluid will spill.
The parts you will need to replace are in any manual: seal, dust cover, snap
ring, shaft, transmission fluid, cv axle, as required.
However, you will not damage the tranny by prying off the side gear shaft.
If this free information has helped you, please let me know.
Any questions that I can answer, I will or I will try and send you in the right
direction.
Old 02-05-2008, 10:11 PM   #4 (permalink)
View blueskypete's Photo Gallery
Can you give me more details on how to do it with screw drivers or the crow bar?
Also, what symptoms caused you to have to replace the side gear shaft and where did you get your replacement shaft?
I've been having problems with my LF CV shaft and noticed that there seems to be more play in the flange mount on the left than the right. I'm thinking something isn't right with the LF drive shaft.
Any suggestions or insight you can provide is greatly appreciated.
pete
blueskypete is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Install side curtain airbag for 2003 Camry LE? helloworld 5th & 6th Generation (2002-2006 & 2007-2011) 8 09-25-2007 10:35 PM
90 Camry Brake Rotor removal ledlung 1st & 2nd Generation (1983–1986 & 1987-1991) 18 03-05-2007 01:55 PM
2007 Camry Reviews 71Corolla 5th & 6th Generation (2002-2006 & 2007-2011) 17 01-16-2007 10:54 PM
