widebody ae86 from so cal ....whad ups?? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Go Here First > Introduce Yourself Here
Introduce Yourself Here Let us know all about yourself and your car. Break the ice in here.
Old 02-26-2008, 02:11 AM   #1 (permalink)
View darkevildrifter's Photo Gallery
Japan widebody ae86 from so cal ....whad ups??
Well its not finshed yet but i say what the hell (when is a car ever finshed?!?!?!) .....build time so far 4 weeks .as most of yu kno i smashed and totaled my coupe so i started over again for the 3rd time..started out with a bare shell 1986 hatch back.. i mean nothing
DEATH AND A NEW BIRTH
so heres a small list of mods....
Suspension---------
cusco Pillowball Tension Rod w/ sub frame
cusco Control arm-rear upper, N-1link
cusco Control arm-rear lower, N-1link
cusco Strut Bar, Type OS, Front
cusco Strut Bar, Type OS, Rear
cusco Tri Bar, Type OS, Rear
cusco Lower Bar, Radius rod, Front
cusco SWAY, 20MM, REAR
cusco SWAY, 23MM, FRONT
cusco Transmission Mounts
cusco Motor Mounts
cusco Lateral rod rear - adjustable
ALL cusco TRANZA bushings
Ueo outter tie-rods(smashed the inner)
Greddy Type-S coilovers
Greddy Camber plates
T3 traction brackets
T3 rack bushing
Aerodyne c piller bar
Autopower half cage
Custom rack spacers
Hybrid Manuel rack
Kaaz 2way lsd
Brakes---------
Project Mu slotted rotors
Project Mu B-force Pads front and rear
Project Mu Teflon Brake lines with clucth line
Bradi cross drilled rotors in the rear
Aerodyne master cylinder brace
new master cylinder
new clutch cylinder
Body---------
Outside
100% spot welded
sand blasted to make sure no sound denting crap was left over
Brand new front window
Solex locks
BADASSSS rising sun hood
Sr5 mirrors
full vertex kit
front kouki brackets
rear kouki brackets
front widebody jblood fenders
rear widebody jblood fenders
White line Kouki tail lights
Inside
cusco spin turn knob
T3 short shifter
cusco shift collar
Video cam mount
Spaco Sprint seat
Sparco 4 pt harness
Momo steering wheel
Hello Kitty horn button
Hello kitty trd badge
Hello kitty Shoulder pads
Split HUb
Apexi EL2 Gauges
Tach
water temp
oil temp
oil pressure
Boost
Apexi Rev/speed meter
AutoMeter Gauges
Fuel level
Voltage
Battery kill switch
optima battery yellow top
wats in the front 14x7 -12(with a 5mm spacer)
Centerlines in rear 15x9 -34
Engine(in car)--------
4age bluetop
Trust sandwich plate
Turbo 2 rx7 fuel pump
cusco Oil Catch Can
Hks Mushroom intake
Trd 4-2-1 headers
Trust DD exhaust
Sun auto Grounding kit
pass crank pulley
r1 wurks alt pulley
(out of car still building)
4agze
Trust oil filter relo kit
Hello kitty Oil cap
Hks supercharger
Hks cam gears
Hks intake mini
Greddy bov
Trd Fuel pressure reg
supra fmic
Oversized values with brass retaners
port and polished head
cusco super single clutch /flywheel combo
pass crank pulley
R1 wurks alt pulley
R1 wurks water pump pulley
Still waiting for--------
Hks springs
Hks 9.5:1 pistons
Hks 5AGX crank
Hks exhaust manifold
Hks Hi-power exhaust
Hks bov
Hks Fcon VPRO
Ae101 GZE harness with map
Carbon Hood
Caron Hatch
Ether Works or Te37s
once the gze goes in so does the custom air box, custom dash, and custom headlights
no NRCA i broke them
so far he she is
darkevildrifter is offline   Reply With Quote
Old 02-28-2008, 12:57 AM   #2 (permalink)
nobody likes to say hi?
Old 03-18-2008, 09:35 PM   #3 (permalink)
View bigae86fan's Photo Gallery
hey nice car how do you find the fitment of the widebody fenders and the bodykit? you remember how much it cost? its a nice setup
bigae86fan is offline   Reply With Quote
Old 03-19-2008, 06:20 PM   #4 (permalink)
well the front bumper is a knockoff but other then that everything fits well..the front and rear jblood widebody was 1 g and the rest of the kit was about that too
Old 03-19-2008, 06:53 PM   #5 (permalink)
cool.. i havent decide if i wanna go wide body or just wide flares but yeah nice car
Old 03-28-2008, 10:24 PM   #6 (permalink)
i got fenderflares for sale if yu want them
Old 03-29-2008, 12:29 AM   #7 (permalink)
well right now im looking at buying an ae86 that has flares already on it, but if something changes i might consider them
Old 03-29-2008, 02:07 AM   #8 (permalink)
sounds good
Old 03-30-2008, 03:57 PM   #9 (permalink)
DOHC VTEC
View Nusdogg's Photo Gallery
DAMN! one of kind of AE86 you got there, so how was the drift on that thing?
204whp/157wtq
Nusdogg is offline   Reply With Quote
Old 04-02-2008, 09:18 AM   #10 (permalink)
KINWAY MOTORSPORTS
KinwayTRD's Avatar
View KinwayTRD's Photo Gallery
This car will look so nice with TRD widebody kit
KinwayTRD is offline   Reply With Quote
Old 11-20-2008, 11:43 PM   #11 (permalink)
View gen4drft's Photo Gallery
hey how did you connect the RSM to the blue top ecu? I'm getting a gen2 Apexi Rsm and so far this is the wiring i have:
Ground......to........E1
IG Power.......to....+B
Speed...........to....spd
RPM.....to.........IGF?, G+, G-, Ne?????
Im not sure where to put the RPM, please correct me if the others are wrong too?
gen4drft is offline   Reply With Quote
Old 11-21-2008, 12:28 AM   #12 (permalink)
pm sent
