Originally Posted by tranmatrix08
do you know how to remove the emblems with pins? are the pins removable and replaceable? are the emblems with pins attached with adheisive or the pins? thanks a lot for the help man.
You just pry them off with something that will not damage your paint.(something plastic, rubber, wood, etc).The pinned emblems are one piece molded. I suppose you could cut off the pins and put them back in the holes, but the stuffed holes will still be very noticable.
Use emblem adhesive remover for the ones that are glued on. Your questions woud be better answered in the Matrix forum.
