differential fill plug removal
I am have a tough time with removing the differential fill plug on my 2001 four cylinder camry. Couldn't move it with a 17mm socket, tried a closed end wrench and rounded the corners. Tried a set of vise grips but they will not hold. I believe I have thought of and tried everything, so my next move will be to take it to a mechanic, but aside from their ability to stand under the vehicle verses lying under it like have to I can't imagine what they can do that I can't. I am trying to check the fluid level, or even change it, but I do not want to remove the drain plug until I know I can fill the thing back up. What should take an hour at the most ended in frustration after a couple of hours of trying to get this plug out.
It is not conveniently located, so getting enough pressure on it is difficult to begin with.
I would even buy a new tool to get it done if I knew what would work.
Any suggestions would be appreciated.
Jason
2001 Camry
68,000 miles
