Are you the original owner of the vehicle since new? 60,000 seems a little early for valve seals; however, the symptoms does indicate that would be the cause.
To answer your questions:
1) It is possible for the amount of oil used, but it also depends on type of driving. And compression test won't show valve seal problem, and neither would it show if the oil rings are stuck; it only proves that the compression rings are sealing. How was the vehicle being used, short distance driving? Are there any sludge build-up inside the valve covers? You may want to ask your dealer if they can use a bore-scope to look inside the front cylinders. It just might give some indication of how the cylinders are; if the crosshatch marks are missing or if the piston tops are washed down with oil, it maybe indication of major engine work is needed.
2) and 3) I am not sure about the cost but the valve seals can be replaced without removing the cylinder heads.
If you are the original owner, and because the vehicle has only 60,000 miles, I would suggest contacting Toyota and see if they will give you some assistance for the repair cost. Won't hurt asking, one can never tell.
Good Luck,
N.E.O.
