Locked Motor - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Go Here First > Introduce Yourself Here
Introduce Yourself Here Let us know all about yourself and your car. Break the ice in here.
Old 09-04-2008, 09:54 PM   #1 (permalink)
View deaganconnor's Photo Gallery
Post Locked Motor
Whats up my name is Matt.
I don't own a toyota, but I wheel with a friend that does. The other night while backroading we tried a river crossing which resulted in water in the motor. After removing it from the water with a winch we pulled the plugs and finally got it to turn over. After putting new plugs in and starting it rattles really bad like a bent valve or something. If anybody has any idea what it could be we would be very grateful. He has a 1994 toyota pickup with a 3.0 v6, 32x11.50s, and a 9000 warn winch. I drive a stock 97 Wrangler but I'm working on that.
deaganconnor is offline   Reply With Quote
Old 09-04-2008, 10:00 PM   #2 (permalink)
View toyomoho's Photo Gallery
After pulling the plugs did you turn the engine over to blow out any water in the cylinders?
Any water in the engine oil, trans, etc?
Old 09-04-2008, 10:04 PM   #3 (permalink)
just a nobody
Hydro-lock an engine can cause all kinds of problems. Do a compression test on it will probably give you some idea where you are at.
N.E.O.
