To remove the freeze plug is the easy part, just knock a hole in it and pry it out, of course after you had drain the coolant. Installing it will be a little different, having an installer would definitely make the job a lot easier. If your dad is a mechanic, maybe he will have the properly tool to install the new one. Usually, you just knock the old one out, clean out the hole, put some sealer n the new plug and hammer it back in with an installer.
Not sure which one you are replacing, so can't exactly tell you any more than that. Which freeze plug is leaking? How does the coolant look, rusty?
N.E.O.
