http://smg.toyotapartsandservice.com...2005&int_id=12
Replace engine oil and oil filter 1
Rotate tires
Lubricate propeller shaft (4WD)
Re-torque propeller shaft bolt
Replace engine air filter
Replace cabin air filter (if equipped) Inspect the following:
Automatic transmission fluid
Ball joints and dust covers
Brake lines and hoses
Brake linings/drums and brake pads/discs 7
Charcoal canister 8
Drive belts 9
Drive shaft boots (4WD)
Engine coolant 10
Engine valve clearance
Exhaust pipes and mountings
Front differential oil (4WD)
Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
Fuel tank cap gasket
Radiator, condenser and/or intercooler
Rear differential oil
Steering gear box
Steering linkage and boots
Transfer case oil (4WD)
Welcome to TN!!
