2007 4runner service requirements? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Go Here First > Introduce Yourself Here
Introduce Yourself Here Let us know all about yourself and your car. Break the ice in here.
Old 11-07-2008, 06:33 PM   #1 (permalink)
View sculli28's Photo Gallery
USA 2007 4runner service requirements?
Hello there. This is my first time in any kind of forum, so not sure what to do. Here is my question: I own a 2007 4runner and it is due for it's 30,000 mile service, but the dealership wants to charge me $700 for the maintenance. I feel that is way too high. I'm kind of ignorant when it comes to vehicles so I was hoping someone could clue me in on what service is absolutely necessary at 30,000 miles. I've taken it to the dealer for the other mileages, but this is just too much. In the dealership's description of what they will do, they utilize the word "inspect" which to me means look at and not touch. The labor seems to be the majority of the cost, 5hrs worth. (so I was told) I don't feel all the steps the dealership's going to take are necessary. Someone please clue me in. Thank you ahead of time.
sculli28 is offline   Reply With Quote
Old 11-07-2008, 06:43 PM   #2 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $1003264
View humanoid's Photo Gallery
Hello and welcome to the forum. 30K mile maintenance usually includes:
Replace engine oil and oil filter
Rotate tires
Lubricate propeller shaft (4WD)
Replace spark plugs
Re-torque propeller shaft bolt
Replace engine air filter
Replace cabin air filter (if equipped)
Inspect the following:
Active height control gas chamber 3
Ball joints and dust covers
Brake lines and hoses
Brake linings/drums and brake pads/discs 4
Drive shaft boots (4WD)
Engine coolant 5
Exhaust pipes and mountings
Front differential oil (4WD)
Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
Fuel tank cap gasket
Radiator, condenser and/or intercooler
Rear differential oil
Steering gear box
Steering linkage and boots
Transfer case oil (4WD)
Transmission fluid or oil
Additional Maintenance Items for Special Operating Conditions:
Driving While Towing
Replace front differential oil (4WD)
Replace manual transmission oil
Replace rear differential oil, including limited-slip
Replace transfer case oil (4WD)
Tighten nuts and bolts on chassis
Driving on Dirt Roads or Dusty Roads
Most of the stuff you can DIY if you can turn a wrench or have a friend help you out. Don't get raped at the $tealer and save some $$$ by doing it yourself.
This is my sig.
humanoid is offline   Reply With Quote
