sick rav needs help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Go Here First > Introduce Yourself Here
Introduce Yourself Here Let us know all about yourself and your car. Break the ice in here.
Old 11-11-2008, 08:51 PM   #1 (permalink)
View steve white's Photo Gallery
Unhappy sick rav needs help
Hell-o my name is Steve, I own a 2002 Toyota Rav4 automatic with 110,000 miles on. The other day the check engine light call on , plugged in my scan-tool and got code P1135, I changed the O2 upstream sensor on right side of engine but light comes back on. I need some help, thank-you, Steve
steve white is offline   Reply With Quote
Old 11-11-2008, 08:56 PM   #2 (permalink)
just a nobody
You may have change the wrong one, bank 1 sensor 1 in your case is the one on the driver's side. BTW, it is an A/F sensor.
N.E.O.
Old 11-11-2008, 09:11 PM   #3 (permalink)
Thumbs up sick Rav
You are right about that being a A/F sensor, The sensor that I changed is on the driver's side. Thank-you, Steve
Old 11-11-2008, 09:26 PM   #4 (permalink)
just a nobody
So you did change the right sensor and the light is still on?
N.E.O.
Old 11-11-2008, 09:39 PM   #5 (permalink)
Yes the light came back on same code P1135
Old 11-11-2008, 09:45 PM   #6 (permalink)
just a nobody
Did you use a Toyota sensor? Did you check for 12V across the terminal for the heater circuit of the connector?
N.E.O.
Old 11-12-2008, 04:03 PM   #7 (permalink)
Bosch sensor, Sorry but it's all I could afford, I will check for 12 volt at the plug tonight, Thanks for your insight, Steve
Old 11-12-2008, 04:19 PM   #8 (permalink)
just a nobody
Check and compare the heater element resistance between the two sensors, the Toyota one and the Bosch one. It is possible the resistance value difference causing higher draw in the Bosch sensor.
N.E.O.
Old 11-15-2008, 02:10 PM   #9 (permalink)
Thumbs up
Thank-you, N.E.O. you where right about A/F sensor, Put a Toyota sensor in, problem solved, wife's baby running fine, Thanks, Steve
Old 11-15-2008, 03:21 PM   #10 (permalink)
just a nobody
Great!
Enjoy your ride, and drive safe!
N.E.O.
Old 11-16-2008, 10:26 PM   #11 (permalink)
Chris Tacoma's Avatar
View Chris Tacoma's Photo Gallery
Hi Steve, welcome to the forum
05 Tacoma access cab
Chris Tacoma is offline   Reply With Quote
Old 12-06-2008, 01:34 PM   #12 (permalink)
View ncroiger's Photo Gallery
AFR 2002 Highlander
Hi,
I have a 2002 Highlander (V6) and I had a code of p1135. I replaced Bank 1 Sensor 1 with a new Bosch AFR Sensor.
The check engine light and VCS light went off, but now when I start to drive only the VCS light comes back on.
I checked again for codes and there were none. The dealership was confused about this as if there is a problem a code should could up. I don't want to bring it to the dealership and pay $$ to find out nothing is wrong.
Could this be related to using a Bosch sensor vs Denso?
Any help would be appreciated.
ncroiger is offline   Reply With Quote
