hello from southern oregon my name is mike i own two tercel wagons one fwd and an sr5 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Go Here First > Introduce Yourself Here
Introduce Yourself Here Let us know all about yourself and your car. Break the ice in here.
Old 04-20-2010, 05:00 AM   #1 (permalink)
View feltcher's Photo Gallery
i don't know if i'm doing this right does anyone know if 1986 mr2 rims will fit my 1983 tercel sr5
feltcher is offline   Reply With Quote
Old 04-20-2010, 05:36 AM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $955015
iTrader Score: 16 reviews
Welcome to the forums. I just did a bit of searching on the net for you and found out that the offset for standard MR2 wheels is 39mm. Unfortunately I couldn't find what the offset is for an 83' Tercel. If you can find out what the offset is for your standard Tercel SR5 wheels then you'll be able to find out if they'll fit with no problems. If you're having a hard time finding out, then try having a look on the inside of the rim as it may be stamped there. If not, then you can easily measure it yourself by taking the wheel off.
As far as I know, they're both 4x100, so they'll fit in that regard, but if the offset is greatly different then you'll experience problems with rubbing and/or clearance. Once you've found out the offset for your current wheels, head along to this site and use the calculators to find out what the differences will be:
http://www.carbibles.com/tyre_bible_pg4.html
It might pay to create a thread in the Tercel section of this site in case anyone has had experience in fitting MR2 wheels to your car.
Best of luck
Old 04-20-2010, 11:15 AM   #3 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3643050
Like Kiwi suggested, you should take a look at the Tercel forum and see if your answer is there. Welcome to the nation!
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
