I made a boo-boo, need help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Go Here First > Introduce Yourself Here
Introduce Yourself Here Let us know all about yourself and your car. Break the ice in here.
Old 05-02-2010, 07:38 AM   #1 (permalink)
View shawna's Photo Gallery
Hi, Shawna here and first time on this forum. Yesterday I added window washer to what I thought was the window washer resevoir, needless to say, silly me, put it in the radiator resevoir. What do I need to do. I drove it after I did it and didn't find out till later that I did it wrong...
shawna is offline   Reply With Quote
Old 05-02-2010, 09:04 AM   #2 (permalink)
View QUINNSTIGATOR's Photo Gallery
Shawna what you should do is syphon the resevoir with a small piece of hose. put the hose all the way into the resevoir, put your finger over the top, pull as much of the hose out as you can while leaving the end of the hose at the bottom of the resevoir. Put the end in your hand low to the ground in a bucket and begin syphoning. DO NOT SUCK ON THE END OF THE HOSE! Engine coolant is harmful or fatal if ingested. Syphon into a bucket or pail, place in temporary container, and dispose of at your local parts store that accepts old fluids.
QUINNSTIGATOR is offline   Reply With Quote
The Following User Says Thank You to QUINNSTIGATOR For This Useful Post:
shawna (05-02-2010)
Old 05-02-2010, 10:54 AM   #3 (permalink)
thanks
Thank you for your help. Another question...After I do that should I refill the tank with anitfreeze? Do you think I need to get the car checked out?
Shawna
Old 05-02-2010, 01:58 PM   #4 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3643050
to Toyota Nation, Shawna! BTW, what model of Toyota do you drive?
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 05-02-2010, 03:01 PM   #5 (permalink)
boo boo
Sorry, I have a 2010 Camry. I went ahead and syphon'd the antifreeze out of the resevoir. I talked to a person at the auto zone and he said that it should be alright. Just filled up the resevoir with antifreeze again, and the window washer in the right resevoir! Dumb me...
Old 05-02-2010, 03:03 PM   #6 (permalink)
Do you feel lucky?
TrailDust's Avatar
Don't feel badly, it's a fairly common mistake. Consider it a lesson learned.
2002 Avalon XL
Old 05-02-2010, 03:13 PM   #7 (permalink)
Thanks, that makes me feel better!
Old 05-02-2010, 03:51 PM   #8 (permalink)
Do you feel lucky?
TrailDust's Avatar
There's hardly a certified mechanic out there who hasn't filled four or five quarts of oil in a car only to find he didn't put drain plug back in. Clean up on aisle one!
2002 Avalon XL
