Thanks for the warm welcome, TrailDust and BlueMeanie!
I live and work in Moberly, which is 30 miles north of Columbia. This is the part of Missour-ah where the corn- and soybean fields rule; where the cattle roam free (within their fenced pastures, of course); and I'm the guy who doesn't drive a pickup.
They look at me weird over here.
And no, I'm not originally from this area. If I were, I'd probably have a pickup and a bit of a southern-style accent.
Welp, I did the front brakes and didn't have a problem at all. Definitely different than I remember when I was a kid when FWD cars were limited to the Olds Toronado.
So today when I go to tackle the rear drums, I get the drums off just fine and even with 146K on the clock, the rear shoes look like maybe 1/16" has been worn off. So there's no need to replace the shoes.
However, I noticed that one of those counterweights fell off the drum. This is not good, as it was tack-welded on poorly to begin with and with the rust and whatnot, it had fallen off. To make matters worse, I saw a spot where there USED to be a counterweight and nothing was there, meaning, of course, that one had fallen off some time ago.
This makes perfect sense. The drums are out of balance. This puts additional load/work on the rear shocks AND I get an out-of-balance shimmy in the entire minivan at speed. It's annoying.
I called and checked around and discovered there's no real way to balance rear brake drums. They can turn them just fine, but balance? No way, Jose.
As I don't want to have to put another set of rear shocks on the van anytime soon, I have to replace the drums apparently. The linings are just fine - no severe grooving at all. But they're out of balance and that spells trouble down the road....
Let me add a bit more detail about this brake drum being out of balance, as I think it's important.
First off, I have a 2004 Sienna LE.
With about 80K on the clock, I noticed a sound from the rear that I couldn't quite put my finger on. I went through the usual balance-the-tires thing with no real effect. The sound gradually got louder. I finally took it in to a tire place and he noticed that the rear shocks were gone - the seals had partially failed and the shocks wore a collar of hydraulic fluid.
At this point the van probably had about 100K on it.
Okay, so I put shocks on it. Oddly enough, the sound went away so I'm thinking that the problem is solved. Now with about 145K on the clock, I'm hearing that sound again -- it sounds like something out of balance and I get a slight shimmy in the steering wheel.
I went ahead and did the front brakes and as I mentioned up-thread, when I did the rear brakes I noticed that a counterweight had fallen off one of the drums. The other drum showed a spot where a counterweight USED to be, and this was the tire that had the most noise.
I called a couple of parts stores in town. They all turn drums but none of them balance drums. They basically said that if you have a balance problem, you're basically screwed. You have to buy new drums.
So I started looking at drums. A few brand names popped up and I checked on the most "premium" of the group. I asked the question if brake drums are manufactured such that they are balanced without counterweights (like rotors) or if they all come with the counterweights tack-welded on the face plate -- answer: they all come with the counterweights tack-welded.
So it's reasonable to expect that these counterweights will, at some point, fall off the drum. When that happens, a balance problem occurs and it has an impact on the shock absorber, causing premature wear.
Lesson learned for me -- spend the extra money up front and get rear disc brakes. This drum brake business is ancient technology!
