If you pull it out the wires attach at a plastic clip on the back. Since it gets hot the plastic can deform or become brittle, break and detach. If thats what happened cut it off and replace it with two common female butt connectors.
Also, my wife's used 06 Volvo came with a non working cig lighter in front. After getting no results from replacing the blown fuse, I took it to a dealer and they quoted me a couple hundred to fix it. They also mentioned that it looked like some one had spilled soda in it or something. I took it home, popped it out, cleaned it good with Goo Gone, isopropyl alcohol and and a bit of 400 grit sand paper and it works fine now.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
