Originally Posted by TrailDust
Congratulations on the great find!  Any modding plans in the future?
Thanks! No mods, per se, but I have just put some money into it gettin' her close to perfect. Brand new set of Kelly Safari ATR's LT265/75r16 load range C, Polyurethane bushings for the rack & pinion from Wheeler's *Dan @ Wheeler's rocks btw
*, front end alignment, changed the front diff/rear diff/ & transfer case to Castrol Syntec 75w90 full synth, had the Yota Dealer drain the trans. pan and refill with 5 qts of Type T-IV, engine oil and yota filter change with Castrol Syntec 5w30 full synth, Yota engine air filter, yota PCV valve, Timing belt job & replaced water pump, t stat, all 3 drive belts, and the oil seals inside the timing cover, done by a Master Yota tech, Sylvania Ultrastar Headlight bulbs, Michelin rubber floor mats...all this done within the last couple weeks lol!
* I do plan on throwing a Hitch on her sometime soon, and maybe a tonneau/roll-up softcover....or a toolbox, haven't made up my mind yet lol! Maybe a nice lil Bilstein 5100-oriented lift in the future.
