Auto-X Tip - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition > Auto Cross
Auto Cross Discussion area for question and answers related to auto cross racing.
Old 02-09-2003, 03:46 PM   #1 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $625265
iTrader Score: 6 reviews
View EKam's Photo Gallery
Auto-X Tip
From Gibson99 (from CamryMan.org)
most autox isn't real taxing on your brakes. it's your tires in the corners. make sure you pump them up to at least 38 psi. get some chalk (like the little kids use on the sidewalk/driveway, ya know?) and make some marks on the edges of your tread. this will help you gauge tire pressure. make the marks & make a run. if they rub off, you need more air, if they dont rub off you have too much air.
EKam is offline   Reply With Quote
Old 02-09-2003, 05:41 PM   #2 (permalink)
The terrorist
View Xenon's Photo Gallery
What is this all about? I don't understand a thing Dickson?
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
Old 02-09-2003, 05:58 PM   #3 (permalink)
Music nerd?
View Warped's Photo Gallery
Soo...how can you tell if you have just the right amount?
Warped is offline   Reply With Quote
Old 02-12-2003, 12:39 AM   #4 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
a common approach at tire pressure...
the method described above is to mark ur sidewalls and drive around...
if after a lap u see that the chalk has rubbed off then u need to add more air into the tires to increase traction(BTW this is only applicable to auto-x).
u just keep adding till it's good. of course, there is a point where u have too much. usually the ppl go 40psi(civic drivers)
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
boroEF is offline   Reply With Quote
Old 02-17-2003, 10:39 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
why not just use a tire pressure gauge? :P
Old 02-17-2003, 10:48 PM   #6 (permalink)
EKam's Avatar
Notice the topic says "Auto-X tip".
18/6/08 - Sayonara Kamuri!
Old 12-17-2004, 11:37 AM   #7 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
I guess I'll be of some use to this forum....
Here's a tire that has been chalked:
If your tire is over inflated, not all of the tread will be making contact with the ground and therefore not all polish on the tread will wear off.
If your tire is underinflated, the tire will rollover onto the sidewall and wear off the polish there. This is obviously bad, because sidewalls were not made to grip.
If your tire is inflated correctly, only the tread will contact the ground during your runs. The chalk or shoe polish will wear away on the tread, and not the sidewall.
If torque actually won races, wouldn't we all be driving diesels?
nort0188 is offline   Reply With Quote
Old 12-17-2004, 01:12 PM   #8 (permalink)
Auto-Cross Addict
SmokingTires's Avatar
View SmokingTires's Photo Gallery
If your not on the gas, your on the brake. But your never coasting. Coasting is time you could be doing one or the other.
Alloys are stronger than steelies in the terms of flex/strangth
Watch your speed coming into slaloms. You may even want to slow down beyond what you think is right. Coming into a slalom to "Hot" will send you into a spin. You can always accel once you are in it and have the groove down.
Always walk the course before hand. Figure out your line ahead of time, keep in mind which side to take on optional slaloms.
Pace out the cones in slaloms to see if the distance changes. This will help plan out your entry.
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
SmokingTires is offline   Reply With Quote
Old 12-17-2004, 01:46 PM   #9 (permalink)
Rated H: Chikan Sukebe
Sportivo Concepts's Avatar
View Sportivo Concepts's Photo Gallery
Actually the same rules apply to other automotive sports, not just auto-x
because each course is different and requires your tire to be at certain psi ro run properly..... for instance lets take Sebring forexample where I run quite regularly, for best rire performance and tread life and so forth I run 10-20 psi lower of what is on the tire, I hit all my lines, with not chalk rub off. the reason I sy 10-20 lower is because at any given time it can be really hot or really cool so the 10% lower is usually for the coolers days and I run the 15-20% for the more hotter days cause of the heating of the air inside of the tire will expand and create more pressure.
another example is lets say I'm running at Poconos Raceway (i never been there), the track is completely different from Sebring so I need to find the right pressure i need to run and a tire guage wont tell you that your running on your sides or how the tire is performaning on the course
Cars: 07' Caddy CTS 3K Miles & Dying
News: Accepting Pics/Articles For New Toy/Lex Scion Mag
Important Threads: Guide To Nitrous
Sportivo Concepts is offline   Reply With Quote
Old 12-20-2004, 08:06 PM   #10 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Geez guys, this is all in Brink's guide to auto-x. Way to repost.
http://www.toyotanation.com/articles/autox-guide.php
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 12-21-2004, 08:14 AM   #11 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
One thing that's not in the guide is this: At last season's last event, there was a guy I spoke with who drove a mostly stock lancer... only thing he had done was RSB. He said that ever since installing it, he always spun out. Wasn't sure if it was the sway or his inexperience causing that, so he got a seasoned autoxer to drive the car on the course. but they spun out, too.
I can't recall if he'd changed any other suspension parts, but we basically came to the conclusion that his particular rsb was way too beefy and caused massive oversteer, so I advised he use the chalk method to gauge the point of underinflation and set his front tires just below that point. Helped a bunch for him, because the front underinflation promoted understeer which he could handle better than the snap-oversteer he was experiencing.
So the chalk method is also a sort of gauge to use for tuning your car's handling for a particular course sometimes outside the realm of simple tire traction.
-- Jonathan W.
http://camry.wanthoney.com
http://fleshy.org.nz/yum/
brink is offline   Reply With Quote
Old 12-21-2004, 09:12 AM   #12 (permalink)
Auto-Cross Addict
There's more info out there than even the great brink knows
Old 12-22-2004, 01:35 PM   #13 (permalink)
not actual size
brink's Avatar
What you talking about, I know everything!
Yeah, my guide is just a general overview. It is by no means the definitive source.
-- Jonathan W.
