upgrading brake system/ideal brakes? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition > Auto Cross
Auto Cross Discussion area for question and answers related to auto cross racing.
Old 03-02-2007, 12:33 AM   #1 (permalink)
View mr2poweraw11's Photo Gallery
Gen1 upgrading brake system/ideal brakes?
I hope someone can add to the pros and cons, no one in the mr2 forum has, but my rx7 friends have. The 85-86 rear brakes differ from 87-89, the later models i believe came with bigger rotors to reduce warping. Since my rear brakes failed, and im lazy, im looking to basically upgrade everything (brake system) while im already going to work on the car.
Here are my questions,
1.85-86 and 87-89 use the same size brake pads, so how is performance different?
I know the 87-89 discs are thicker, so more reliable? but thicker probably means heavier, which means rotating weight right? My friend also pointed out that bigger rotors means better leverage (at least in rx-7s).
2. what can i do to shorten stopping distance?
Heres a list from what i believe would help.
TIRES!
WEIGHT REDUCTION.
BIGGER CALIPERS/MORE PISTONS
BRAKE PADS
as far as drilled, slotted, brake lines, the stupid master cylinder lock thing. brake air ducts. i've seen somewhere a guy posted all sorts of hip brake upgrades, but it only shorten the stopping distance by a few feet. But everyone agrees that the feel improves, but reliability and maintance can go either way too.
Any advice? i know the early mr2's are pretty limited to aftermarket support, im hoping some of you guys will help.
mr2poweraw11 is offline   Reply With Quote
Old 06-15-2007, 01:27 AM   #2 (permalink)
View broke's Photo Gallery
Rotors and warping... many times it is about the metal used in the Rotors that will be the determining factor. Cheap rotors are generally made with crappy metal that warp easily. All you really need for rotors is a good set of American made rotors. I would only replace/upgrade to slotted or drilled depending on what you are doing if I had to replace my rotors.
Pads:
Low dust ceramic is all you really need.
The above are only a couple of ideas for a lower buck approch.
Are the Early MR2's Disk up front drum in the rear?
You can spend a lot of money on brakes, and not really improve stopping distance, but that two feet that you cut off may be the two most critical feet you have ever seen.
broke is offline   Reply With Quote
Old 06-20-2007, 03:45 PM   #3 (permalink)
Feel the vibe.
vibebreaker's Avatar
View vibebreaker's Photo Gallery
being able to stop a few feet earlier is a good feat i think.
vibebreaker is offline   Reply With Quote
Old 06-23-2007, 12:19 AM   #4 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Bigger rotors only give more leverage if the caliper is moved outward.
The most important thing to fight brake fade is good fluid. When you push the pedal and it feels like the pads are just sliding on glass, but there is resistance. Your pads suck.
If you push the pedal and it goes to the floor. You're boiling your junk brake fluid out of the caliper. Replace it all and use a higher quality fluid.
From there, in all honesty, if you have the ability to lock tires at any speed you will see. Upgrading the brakes does nothing. The problem is avalible traction.
Drilled rotors are moronic.
Slotted rotors stop slower than blanks unless you're melting the pad face - which is not to be confused with boiling your brake fluid out, are more expencive, and SIGNIFIGNATLY decrease pad life.
Hard brake lines make a "differance" when your normal lines are completely shot.
Without even changing calipers, you could always try to find a bigger, stronger assist & master cylinder and bend your brake lines to fit.
AFA will they swap. I don't know, ask on mr2oc or mr2board. If you've not figured it out yet in the tighter communities, all the same members frequent all the same forums.
If nothing else, grab a caliper, a rotor & see for yourself. It's not that much work to take a caliper off. especially if your brakes are currently out anyways.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 09-14-2007, 03:10 AM   #5 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
TIRES!
WEIGHT REDUCTION.
BRAKE PADS
The 88/89 brake are probably all you are going to need. They are way better then the earlier version. The calipers are larger too if I remember correctly. I used to drive my 88 SC really hard with no brake fade. Unless you are putting on really wide tires, you don't really need better brakes. Spend your money on suspension/wheel/tires and a stronger clutch first.
There is so much information about modifying mr2 mk1's you could read for a week. Use google and do a search. www.cardomain.com also has quite a few.
Rapid Roy is offline   Reply With Quote
IIM - Ksport Procomp Big Brake Kits - 8 PISTON!! ImageInMotion Supporting Vendor Sales 8 07-08-2008 01:21 AM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-30-2008 12:33 AM
what kind of brake pads do i need for ae101 front dual piston brakes lifeisviewtiful Archived Corolla threads 3 10-15-2005 02:43 PM
Brake Cooler (Coming soon) Your Uncle Moe General Discussion 11 01-12-2005 01:07 AM
Brake Lines bluerogue85 Camry & Solara Lounge 15 08-11-2004 03:01 PM
