Hey there boys and girls, Well im putting together a circle track car a 77 Toyota Corona, currently it has a 20R engine in it, but i gotta pull that out and rebuild it. But at the time being Im building a 22R (Pre 84 block) with 20R Head. Now we cleaned it at +.030" What would you suggest so i can go fast and spank the pintos?
I am under Nascar Regulations and they state;
-Maximum displacement is 2550 CC's (including wear), Can not exceed 10.00-1 Compression.
-OEM Stock and Hyperutectic pistons only (I got Kb-Sivolite Hyper. Replacement).
-Maximum Cam Lift measured at the valve is .480".....What type of cam should i go with?
Now what can i use, what do you recommend? The block cleaned at .030 and needs to be decked, havent gotten it decked just yet were waiting on the pistions. How far should i go on Head CC's to know what compression ratio i will have, I want to go as close as possible to 10.00. I can not port or polish heads, Basically everything is stock... Please help
Bryan Hendryracing.com
Brody5150@aol.com
