Hello,
Thanks for posting the Navigation install tips for an '07 Camry XLE. I have an '07 XLE as well and have purchased a factory nav unit to install. Would you be able to tell me where you tapped into the amp wiring harness for the speed sensor wire? How about the reverse wire? Is the harness in the same area as the radio or will I need to remove a different section of the dash/console? Looking forward to the install and would appreciate any info you might have.
Thanks,
Jason
2007 Camry XLE 4cyl w/ JBL (soon to be factory Nav!)
