Originally Posted by bjeremi
Please someones gotta know something
I don't know anything.
My wife's 2003 SE and my 2004 SE both came with the fog lights stock. But I recently took the back seat and trunk on my 04 apart and found that the wiring harnesses had all the options wired into the harness even if I didn't have those options. The wire connections were just covered by the interior body panels. That makes sense to have only one wiring harness instead of 4 or 5 for the different packages. So have you looked at the stock wiring harness coming off of the headlights??? There should be a empty connector in the wire loom. It may be a couple of feet back since it's not being used and was probably tucked into the loom to clean up the excess wire. If there is one and you could find it that would simplify your life tremendously.
Mike
