My car was running fine and i was sitting in it and all of a sudden it just
died, checked the battery, checked the gas, its not either one of those. I
don't have a clue and i don't want to start buying things i don't really
need. Please help!
"drgfly" <sewell0727@hotmail.com> wrote in message
news:e93dc797433cec5a353c7ca883629a7c@localhost.talkaboutautos.com...[color=blue]
> just
> need. Please help!
>[/color]
> just
> need. Please help!
>[/color]
An engine needs 3 things to work properly:
Air (check your air filter to make sure it is not clogged)
Fuel (check the sight glass in the side of the carburetor to see if there is
fuel there)
Spark - pull a spark plug and see if you are getting spark. If #1 spark
plug does not spark, pull the other ones. If there is not spark from any of
the 4 plugs, check the igniter.
Ray O
correct the return address punctuation to reply
On Tue, 04 Oct 2005 15:42:21 -0400, drgfly wrote:
[color=blue]
> need. Please help![/color]
OK, how about a little help? Does it crank but not start? Does it try to
start but coughs out?
And when was the last time you changed the Timing Belt...?
"drgfly" <sewell0727@hotmail.com> wrote:
[color=blue]
Gee...you're sure full of info aren't you...
will it crank?, does it just click?, does it make no sound when
you attempt to start it?, are there any lights on?...will the
horn blow?...
Gord Beaman <gord@islandtelecom.com> wrote in
news:92b6k19rd0no9rodln1j7bapdm8rkq0f23@4ax.com:
[color=blue]
>[color=green]
>>just died, checked the battery, checked the gas, its not either one of
>>those. I don't have a clue and i don't want to start buying things i
>>don't really need. Please help![/color]
> horn blow?...[/color]
Maybe he needs to start using the crank instead. Remember: NEVER wrap your
thumb over the crank!
"TeGGeR®" <tegger@tegger.c0m> wrote:
[color=blue]
>[color=green]
>>[color=darkred]
>thumb over the crank![/color]
Christ yes!...you;re *from* that era aren't you?!!...nobody
*ever* forgot that lesson once they learned it the hard way...
