Engine oil spill on alternator causing rapid battery drain? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2005, 03:44 AM   #1 (permalink)
Vik
Guest
Posts: n/a
View Vik's Photo Gallery
Hi guys,
I accidentally spilled a substantial qty of engine oil on and around
the alternator of my '92 Corolla - and now the battery has started
draining rapidly (0.30 amps with the engine shut off). The mobile auto
electrician has just checked the battery, and says it has a dead cell.
I'm not sure if the problem is with the alternator/regulator (because
of the oil spill), or the battery, which was doing just fine before the
oil spill. Any suggestions?
Thanks,
Vik
Old 10-07-2005, 04:22 AM   #2 (permalink)
mrcheerful
Guest
Posts: n/a
View mrcheerful's Photo Gallery
Re: Engine oil spill on alternator causing rapid battery drain?
"Vik" <vixahuja@hotmail.com> wrote in message
news:1128674677.883436.146500@g14g2000cwa.googlegroups.com...[color=blue]
> Hi guys,
> Thanks,
> Vik[/color]
Disconnect the alternator, if the drain stops then you have found the
problem. A failed cell on the battery can take the alternator in a short
time, so the oil on it may be co-incidence.
mrcheerful
Old 10-07-2005, 06:56 AM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
Engine oil attacks parts inside the alternator and once soaked there is no way to stop it. I suggest replace both and clean ALL the connections on battery terminals while in that area.
雄のハヤブサ
Tercel GTS is online now
Old 10-07-2005, 09:27 AM   #4 (permalink)
Gord Beaman
Guest
Posts: n/a
View Gord Beaman's Photo Gallery
"Vik" <vixahuja@hotmail.com> wrote:
[color=blue]
>Hi guys,
>Thanks,
>Vik[/color]
I'd say that you got two problems, the dead cell and something is
causing a draw while sitting static....I wonder if you got some
oil inside the alt which has 'coked' somewhere causing the 300mA
draw? (mind you, I've never heard of it happening)
You're gonna need to change the battery anyway but that's not
what's causing the draw, you'll need to start yanking fuses till
you get the problem isolated.
Incidentally, how did he arrive at the 'dead cell' diagnosis?
-Gord.
(use gordon in email)
BB code is Off
Smilies are Off
[IMG] code is Off
