Re: Thermostat flavors - 94 Tercel 3E-E
Ralph Innes <haruspex(NOSPAM)@shaw.ca> wrote in
news:Xns96E82B1BFA0B9f35mru20458shawca@24.64.223.211:
[color=blue]
> Hi group!
> My '94 Tercel is running a bit cold - usually about 1/8" above the
> bottom mark on the gauge.[/color]
Your thermostat is bad.
[color=blue]
> Before I pull out the existing thermostat, I'd like to have a
> replacement in my pocket.
> Do you happen to know what temperature values are available?
> And, is there a "standard" one?
>[/color]
194F (90C).
Use only a dealer replacement, and make sure it's installed the correct way
around. Aftermarket thermostats may be cheaper to buy, but are *much* more
likely to cause you problems.
TeGGeR®
