Re: 93 tercel
"Raymond" <noemail@noemail.com> wrote in message
news:61u1f.2$F06.197@news.uswest.net...[color=blue]
> is a tercel a reliable car? I'm thinking of buying another used car for
> work. (next to my 98 corolla, which I will be passing on to my wife).
> if the car doesn't have AC, is it possible to add AC and approximately how
> much would it cost.
> thanks.
>[/color]
Some early 90's Tercels had an electronic carburetor that caused some
drivability problems and was very difficult to fix, were prone to carbon
build-up on the valves, and had valve guide seals that were prone to
leaking. Stick to a Tercel model that is fuel-injected for much better
reliability.
Yes, it is possible to add AC. Toyota dealers may still be able to get you
a kit. Plan on $800 to $1,000 for the kit plus 5 to 8 hours at whatever the
local labor rate is to install it. My recommendation is that it is less
expensive to find one already equipped with AC than to spend the $1,500 or
more to install one.
Ray O
correct the return address punctuation to reply
