more questions about CAT+O2 sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2005, 08:30 AM   #1 (permalink)
wenmang@yahoo.com
Guest
Posts: n/a
View wenmang@yahoo.com's Photo Gallery
Hi, all
I got a lot of kind responses after I posted my original questions
regarding to CAT+O2 sensor. I feel such relief after reading your
responses. So far, the engine check light is still off and I am anxious
to see what will happen next. I have some more questions after reading
your responses:
1. Is it possible that I pumped some "bad" gas that caused the whole
problem? I keep pumping the cheapest gas I can find and never stick to
the brand
2. How could dealer's mechanic tell the internal worn of CAT? Can such
internal worn be detected virtually without taking down the CAT?
3. I am thinking about purchasing an OBD II scanner. If check engine
light is not on, Can I still use it to do some kind of early detection
of my car, e.g., whether the car will pass emission test, etc?
Thanks.
Old 10-07-2005, 09:43 AM   #2 (permalink)
C. E. White
Guest
Posts: n/a
View C. E. White's Photo Gallery
Re: more questions about CAT+O2 sensor
<wenmang@yahoo.com> wrote in message
news:1128691813.727634.218250@g14g2000cwa.googlegroups.com...[color=blue]
> Hi, all
> your responses:
> the brand[/color]
Possible, but unlikely.
[color=blue]
> internal worn be detected virtually without taking down the CAT?[/color]
They can measure the exhaust gas downstream from the converter. If it isn't
meeting specs, the converter would be considered bad. Most likely, they were
just looking for the quick and profitable fix (replace everything related to
the code, fix the problem, and make lots of money).
[color=blue]
> of my car, e.g., whether the car will pass emission test, etc?[/color]
You should be confident if the check engine light is not on, you will pas
the emissions test. That is why the O2 sensor after the converter is there.
It is nice to have a code reader, so you can diagnosis your own problems.
Ed
BB code is Off
Smilies are Off
[IMG] code is Off
