1986 carbureted Toyota Corolla start problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2005, 02:07 PM   #1 (permalink)
Snookums
Guest
Posts: n/a
View Snookums's Photo Gallery
I have a 1986 Corolla (FWD, 4AC engine) with 50K highway miles (all
mine) that over the past few months has gradually become harder and
harder to start, hot or cold. It always cranks fine but either dies
right away or chugs and gradually increase in RPM.
I've checked for vacuum leaks and gone through the factory manual's
procedure for checking the emissions and fuel systems, except for the
tests requiring high altitude or temperature below 45F. I also checked
the carb adjustments (choke opening, base and other idle speed). The
AAC diaphram doesn't leak. The fuel solonoids click when voltage is
applied directly to them. The choke mechanism doesn't bind, and the
choke seems to open gradually as the choke spring uncoils.
Acceleration is fine, hot or cold, at least as well as can be expected
from 75 HP.
A year ago I changed the plugs (NGK), vacuum hoses (all Toyota), and
had the engine checked (175 PSI, 5% leakdown). Oil consumption is
better than a quart per 5K.
What could be the problem?
Old 10-07-2005, 02:33 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 1986 carbureted Toyota Corolla start problem
"Snookums" <snookums@post.com> wrote in message
news:1128712030.065277.289610@f14g2000cwb.googlegroups.com...[color=blue]
> from 75 HP.[/color]
Start with the basics - air, fuel, and spark at the appropriate times and
quantities.
You mentioned choke opening, but how about closing? Does it close when you
depress the throttle pedal to the floor and release it? Of course, this
wouldn't affect hot startup.
On the hard start when it is hot, will it re-start immediately after you
shut it down or do you have to wait for a few minutes?
What is the fuel level in the bowl when it is hard to start? There should
be a sight glass on the carb with some bumps on the side of the housing that
holds the glass. The fuel level should be even with those bumps, about
halfway up the glass. If the fuel level is low, the float might be sinking
or the fuel is draining out somehow.
Are you getting spark when cranking?
[color=blue]
>[/color]
Ray O
correct the return address punctuation to reply
Old 10-08-2005, 11:17 AM   #3 (permalink)
nospampls2002@yahoo.com
Guest
Posts: n/a
View nospampls2002@yahoo.com's Photo Gallery
check the ignition coil, especially if yours is inside the distributor
cap
BB code is Off
Smilies are Off
[IMG] code is Off
