95 corolla valve job ?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2005, 02:18 PM   #1 (permalink)
g20joe1@gmail.com
Guest
Posts: n/a
View g20joe1@gmail.com's Photo Gallery
Hi,
I have a 1995 corolla with 113k miles. I don't believe it has had a
valve job before. Should I get it done?
I really don't know if it's noisy because I recently got it from a
family member and don't have a baseline for that.
Reading the haynes...it says I have to remove the intake camshaft.
Is that right??? seems kind of extensive for just a valve job. Anyone
know what they charge these days for the job?
Thanks
-joe
Old 10-07-2005, 02:32 PM   #2 (permalink)
Truckdude
Guest
Posts: n/a
View Truckdude's Photo Gallery
Re: 95 corolla valve job ??
<g20joe1@gmail.com> wrote in message
news:1128712707.911201.87850@g44g2000cwa.googlegroups.com...[color=blue]
> Hi,
> Thanks
> -joe
>[/color]
If you get it done, let us know if it makes a difference. I have a '95
Prizm (1.8L) with 198,000 miles and it still purrs.
Old 10-07-2005, 02:38 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
> Hi,
> Thanks
> -joe
>[/color]
Your car should not need a valve job with only 113k miles. On the other
hand, at that mileage, it wouldn't hurt to have the valve lash checked and
adjusted if necessary. There is a big difference between the cost of a
valve job, which requires removing the head, and a valve lash check, which
involves just removing the valve cover.
Ray O
correct the return address punctuation to reply
Old 10-07-2005, 06:53 PM   #4 (permalink)
g20joe1@gmail.com
Guest
Posts: n/a
Re: 95 corolla valve job ?? (meant valve adjustment)
Ooops!!
Yes, I meant valve adjustment, not valve job.
Basically the car has a pretty bad idle when cold(1st start of the
morning), then settles down a bit in 5-10 minutes. It actually idles
worse in Neutral then in Drive so I'm thinking the motor mounts have
gone bad(hardened up rubber over time).
As a plan of attack, I was planning on adressing a few maintenance
items:
new plug wires
new fuel filter
new spark plugs
valve adjustment???
new motor mounts?
new thermostat - temperature only reads about 1/3. seems low.
shouldn't it be at 1/2? There is a leak between block and thermostat
housing, so I might as well put a new 180 deg thermostat in.
-joe
[email]g20joe1@gmail.com[/email] wrote:[color=blue]
> Hi,
> Thanks
> -joe[/color]
Old 10-07-2005, 06:54 PM   #5 (permalink)
g20joe1@gmail.com
Guest
Posts: n/a
sorry, I meant valve adjustement. But even for that, the haynes manual
said the intake cam needs to be removed if I read it correctly.
Old 10-07-2005, 08:54 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
news:1128729191.031548.189700@f14g2000cwb.googlegroups.com...[color=blue]
> Ooops!!
> items:
> new plug wires[/color]
Stick to OEM.
[color=blue]
> new fuel filter[/color]
Probably not needed unless you have driveability issues all the time.
[color=blue]
> new spark plugs[/color]
Stick to OEM.
[color=blue]
> valve adjustment???[/color]
Probably worth it.
[color=blue]
> new motor mounts?[/color]
do this last becuase bad motor mounts tend to cause more problems in drive
than in neutral.
[color=blue]
> housing, so I might as well put a new 180 deg thermostat in.[/color]
Get a new OEM thermostat and gasket. Pay attention to how the original
thermostat is oriented when you remove it. Clean up the block and
thermostat housing to get all the old gasket material off.
Replace the coolant (if it is sill Toyota red, stick to Toyota red).
New coolant and a thermostat may solve your rough idle problem.
Ray O
correct the return address punctuation to reply[color=blue]
> -joe
> [email]g20joe1@gmail.com[/email] wrote:[color=green]
>> Hi,
>> Thanks
>> -joe[/color]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
