Re: 1999 corolla left front vibration after braking.
"Nick" <nick.a33@gmail.com> wrote in message
news:1128974733.167988.217420@g47g2000cwa.googlegroups.com...[color=blue]
> Hi Ray O,
> I really appreciate the your effort. I'm sorry about the lack of info
> in the post but this is my first time posting and I welcome any
> questions. To answer your followup questions, the vibration sound is
> only heard when the car is moving and braking. For example stoping at
> a stop sign and moving again. It is not there after the car comes to a
> complete stop from braking, only when I start moving again. The sound
> seems to go away as I accelerate past 20 mph.[/color]
Nick, no offense intended, but your descriptions are terrible. You say
that the vibration sound is only heard when the car is moving and braking
but below, you said that you do not have any vibration when braking.
Does the sound occur when you are braking at low speeds?
Does the sound occur even if you do not have the brake pedal depressed?
Does the sound occur if you are accelerating up to about 20 MPH?
Does the sound change if you are turning?
No one has worked under[color=blue]
> the hood except for oil change. The brake pedal does not slowly drop
> to the floor when I hold steady presure. I am in the US and it is a
> gas engine. I do not have abs. As I said, I replaced the caliper with
> a remanufactured one but it didn't fix the issue. The rotor looks good
> on visual inspection and I don't have any vibration during braking.
> Brake pads are brand new too. It is not a grinding sound but strictly
> vibration and seems to project to the frame under the door. Any input
> would be most appreciated cause I can't figure it out!
> Thanks
> -Nick[/color]
Did you measure rotor run-out when you replaced the caliper?
Did you bleed the brake system after replacing the caliper?
Did you torque the wheel lug nuts evenly in a star pattern?
Ray O
correct the return address punctuation to reply
[color=blue]
> Ray O wrote:[color=green]
>> news:1128725655.073359.266520@g44g2000cwa.googlegroups.com...[color=darkred]
>> > Vibration lasts less then one to two minutes.
>> >[/color]
>> So after you apply the brakes, a vibration occurs that lasts about a
>> minute
>> or two? Does it matter if the car is stopped or moving? What speed?
>> When
>> was the last time someone did work under the hood?
>> If you hold steady pressure on the brake pedal, does it slowly drop to
>> the
>> floor?
>> I had assumed that you were in the U.S. but just in case, does the car
>> have
>> a diesel or gas engine?
>> I think you said that you did not have ABS. Is this correct? (by the
>> way,
>> it helps if you do not cut out relevant information when responding to
>> the
>> post).
>> Ray O
>> correct the return address punctuation to reply[/color]
>[/color]
