Re: Is it My Starter or Clutch? Please Help!!!
On Tue, 11 Oct 2005 10:40:11 -0400, zonie wrote:
[color=blue]
> I would say it is not the clutch or the starter, but likely an adjustment
> problem with the clutch safety switch that hooks to clutch pedal. Scott[/color]
Well, what I posted was the CORRECT way of doing it.
Another way, a little more temporary, is to go to Radio Shack and get some
of those little rubber feet for project boxes, etc and some SuperGlue
(Best glue I've run across yet is Velcro glue. It's used to hold velcro in
place if you REALLY need it to stick, but it works on everything!
Dependin on the switch of course. Some of them worked by pressing the
pedal to te floor, and a piece above the hing would press on the switch,
others worked by getting to the end of the travel and pulling on the
switch. This works for the first.
Locate the switch or the flange. Press the clutch pedal and make a note of
where it hits. Put some glue on the little rubber foot and glue it to
either the flange or the switch. Drive happily for 6 months-2 years or
more!
Um, you'll STILL be upside down and backwards, but for a shoter amount of
time with fewer hands invlolved.
Unless you LIKE cozying up under the dash with a member of the opposite
sex!
OH!!! You may have to trim the rubber foot a little, so have an X-Acto
handy!
