I have seen a bunch of different applications on the web but I am
looking for actual users and their thoughts.
Need software that can be used on a PDA or/and laptop. Prefer USB but
serial is ok. Blue tooth would be wonderful. Also something that can
read wide O2 sensors. Just had to replace the one on my 99 Camry
($185).
My need for something to diagnose car ills is what brings the question
up.
Dan <danielthomas@comcast.net> wrote in
news:jppnk15ncmhetve22l5sv10mlhenh7pp9c@4ax.com:
[color=blue]
> Need software that can be used on a PDA or/and laptop.[/color]
This page hsows the usage of the second one:
[url]http://www.4x4wire.com/toyota/4Runner/tech/OBDII_ECU/[/url]
Might be a good idea to check that your chosen software can be upgradable
to comply with Controller Access Network (CAN), which will be mandatory in
all new cars as of 2008.
TeGGeR®
The Unofficial Honda/Acura FAQ
[url]www.tegger.com/hondafaq/[/url]
have you used any of them? will it tell me or at least help me figure out
what is wrong?
(ie, if my O2 sensor is bad)
"TeGGeR®" <tegger@tegger.c0m> wrote in message
news:Xns96EC99855FAA3tegger@207.14.113.17...[color=blue]
>[color=green]
> Did you see these?
> [url]http://www.autotap.com[/url]
> [url]http://obddiagnostics.com/index.html[/url]
> TeGGeR®
> [url]www.tegger.com/hondafaq/[/url][/color]
"Raymond" <noemail@noemail.com> wrote in
news:QeV2f.63$gz6.2224@news.uswest.net:
[color=blue]
> news:Xns96EC99855FAA3tegger@207.14.113.17...[/color]
[color=blue][color=green]
>> upgradable to comply with Controller Access Network (CAN), which will
>> be mandatory in all new cars as of 2008.
>>[/color]
> out what is wrong?
>[/color]
No, I haven't used them myself.
How do you know your O2 sensor is bad? What symptoms have you got?
If you're in the US (not California though), AutoZone will read the code
for you for free.
yes, I know autozone can read codes, but I need more data.
all I know is p0171 & P0174. and I've googled what those codes are.
I brought it to a mechanic and that's what they said was wrong. I'd like to
be able to figure out myself next time
news:Xns96ECCF23E954Etegger@207.14.113.17...[color=blue]
>[color=green]
>[color=green][color=darkred]
> >>[/color]
> > out what is wrong?
> >[/color]
> for you for free.
> TeGGeR®
>[/color]
news:mWZ2f.114$gz6.2565@news.uswest.net:
[color=blue]
> all I know is p0171 & P0174. and I've googled what those codes are.[/color]
Both are "Fuel System Too Lean".
[color=blue]
> I brought it to a mechanic and that's what they said was wrong.[/color]
How'd they know it was the O2 sensor? Did they use laptop-type OBD-II
software?
[color=blue]
> I'd
> like to be able to figure out myself next time[/color]
Well, laptop-type OBD-II software would certainly help there.
TeGGeR®
1. Had car diagnosed at auto zone for free because the eng ck light
came on. They said it was o2 sensor or MAP sensor per the codes. My
wife actually took the car to Auto Zone since she works within 1/10
mile of the place. She wrote down the codes but forgot where she put
the notes.
2. I went back to the same place about 4 weeks later for a reading of
the error codes. It was P1133. Auto Zone says O2 sensor at a cost of
$120. I was in the area at the time and had surprised my wife with a
lunch date.
3. 2 months later I went back to a different auto Zone store about 50
miles away. Codes were P1133 and P1155. Their code system was down
and they thought it was an O2 sensor.
4. I spent some time on the web only to learn that some 99 Camrys have
"narrow band O2 sensors" and others have "wide band O2 sensors". Now
what do I have? Auto Zone only had narrowband sensors and neither
store had any idea what a wide band sensor was. Just as a note, they
are not interchangeable.
The real diagnosis: My very good friend Bob has a 99 Camry just like
mine. I disconnected his O2 sensor after learning how to
differentiate wide band vs narrow band sensors and measured the
resistance on the terminals. I then compared his readings to mine.
My O2 sensor readings showed an open circuit on all terminals. This
proved to me that mine was defective.
That experience made me wish I had a method of doing some in depth
testing to prove a $185 part was in fact defective before I bought it.
Some testing software which could watch the operation of various
sensors would prove very valuable as On Board Diagnostics become more
intelligent.
5. I ordered a wide band sensor from a local Car quest parts store.
Came in a day later at which time I had to prove to them it was NOT a
wide band sensor as per the notes in their system. None of the 5 sales
folks had any idea what a wide band sensor was even though the sales
person on the phone assured me the sensor was a wide band sensor when
I ordered it.
6 Ordered a O2 sensor for a California car from car quest (seems like
all California built 99 Camry cars have the wide band sensor) at a
cost of $185.
7. Part came in a day later, Installed it , disconnected the battery
to clear the ck eng light and all is OK. Have had no ck eng light for
over 2 weeks even after a 350 mile round trip.
Interesting, removing the ECM fuse for about 15 seconds did not clear
the ck eng light.
Now you know why I am asking for opinions from people who have used
OBD2 software. I have laptops and PDA's so connecting them is no
issue. What I would like is the ability to gain a lot of
information, resetting error codes, eng ck light, reprogramming the
ECU if possible for some minor functions, watching the operation of
the various sensors, etc etc etc.
Hope this info helps someone with their problems. The entire process
took over 4 months. Luckly my car is not due for emissions testing
until Feb 2006.
news:a6aqk1pligm2n0790f15g6gtn962blnl9d@4ax.com:
[color=blue]
> and they thought it was an O2 sensor.[/color]
You may be interested to know that this is a known issue to Toyota. There
are three TSBs having to do with those codes, and Toyota has brought out a
revised Air Fuel Ratio Sensor (O2 sensor) to correct the issue.
I currently have two of those TSBs and am waiting on the third. I can
forward to you if you wish.
Are their any warranty replacements? I had compared me O2 sensor
against my friend Bob's because his O2 sensor was replaced 3 or 4
months earlier. His car (wife's car actually) has less then 30k miles
on it; Mine has over 60k miles on it. Toyota told Bob the part isn't
covered under any warranty by them. His replacement cost was over
$400 at dealership.
Thank you for your information. Dan
On 12 Oct 2005 22:44:57 GMT, "TeGGeR®" <tegger@tegger.c0m> wrote:
[color=blue]
>[color=green]
>forward to you if you wish.[/color]
news:i3psk1p63hm13vd8elat63jr9rgg8nmunp@4ax.com:
[color=blue]
> Please post the TSB's or forward them to me.
> on it; Mine has over 60k miles on it.[/color]
The Federally-mandated warranty is 2yrs/24K miles for all parts except the
catalytic converter, and the emissions and diagnostics computers. Those
three components are warranted for eight years.
[color=blue]
> $400 at dealership.[/color]
Welcome to the wonderful world of sophisticated emissions controls! And
it's gonna get WORSE.
